Timing chain is a bit difficult to do in a car due to the bottom of the timing cover is bolted to the sump.
Things you'll need is timing cover gasket, New timing chain kit(better than buying just a chain) new tensioner. Possibly a few other gaskets depending on what you remove. I suggest doing your water pump while your at it.
The Crow heavy Duty timing set CS6VP (rrp $175) is good Might get it cheaper if youre lucky.
The Basic plan is
Drain cooling system,
Remove harmonic balancer (PITA need puller and usually a rattle gun to remove retaining nut)
Remove Water pump(actually can remain on timing cover just undo the bolts that go through the pump and cover to the block) and anything else in the way of removing timing cover.
Remove timing Cover
Rotate Engine to TDC (easier with spark plugs removed) Both dots on sprockets line up with another (cam dot at bottom crank dot at top)
Remove tensioner (if it's still there
) chain and timing gear/sprocket from camshaft.
Check that the balance shaft timing mark line up with cam gear.
Replace sprocket/s
Use straight edge to make sure both sprockets are aligned
Fit new timing chain and tensioner ( note on tensioner there's 2 types short bolt and long bolt late model vr-to vx run long bolt some late vp's may also use long bolt. Check by examining hole threads starts deeper in on long bolt tensioners)
Check that timing chain does not foul on timing cover or balance gear
Re-assemble everthing Paying attention to make sure your gasket surfaces are clean i suggest using an aviation sealant like loctite No.3
Thats the basics if you got some mechanical skills you should breeze through it. If you dont want to remove sump i suggest using silicone or sikaflex type seleant around the sump so it doesnt leak.
Cheers Pub
PS I Reported that this thread should be moved instead of bitching about people posting in the wrong section
