As I see it the only mistake you made was step 16 should come after every second step
Good write up mate, how hard is it for the gain you get to do the rest of the pulleys?
Yep, definitely a different idler pulley. Not sure how that would work with the 5% OD harmonic balancer you have, as the serpentine belt for the blower will be running at a different speed to the serpentine belt for the engine accessories.
Hi Bart,
They are 2 separate pulleys stacked ontop of each other, so belt speed is no issue, i will post my progess back here for any other L67 owner's once i work it out.
Cheers.
LOl, i didn't think about that till after i replied. Considering they are 2 separate pulleys, maybe someone has fitted the wrong diameter pulley at some stage as there is definitely clearance. Other wise you may need to get the standard ecotec pulley at the back.
edit. just looking at your pic again, the L67's have a smaller idler pulley at the top to clear the tensioner assembly for the m90 serpentine belt. If Holden wanted to use the same belt length they would have increased a pulley size else where to compensate. It looks like they possibly made the lower idler a bigger diameter for this reason????
