How to identify a VL Turbo 5 speed manual gearbox?
VQXTC
3rd planet from the Sun...
HSV VP Senator, VY SS Crewman
Hi there all, is there any way to identify a vl turbo 5 speed manual gear box?
eg> serial numbers etc......
jatsvl
NEEDS MORE POWER!
vl exec wagon
other than MX7 for turbo.:) and
MF5 non turbo australia ME7 non turbo new zealand
I can't help!:bang:
35
Cairns, QLD
VS S Pack Ute
The mx7 is big. Thats basically the only easy difference so far as i know. The mx7 (turbo box) will pretty much fill up the entire tunnel. The mf5 will leave a fair bit of space around itself. Post a pic?
FuzzayD
89 VN Executive 3.8i
so if i was to be buying a 88 vl calais turbo how would i know it has the right gear box?
HOLDEN4life
Power of The CALAIS
liverpool (western suburbs sydney)
www.shantek.holden4life.com.au
Vl Calais
you can check the VIN number to see if its a genuine calais turbo the first 7 letters WOULD go like this
8 X 19 8 H
8= standered code
X= calais
19= sedan
8= 3.0ET (turbo)
H= 1988
if its a genuine turbo 5 speed it would say TRANS.MX7 on one of the compliance plates
now to check the actual gearbox for turbo 5 speed the Serial Number Plate is attached to the right hand side of the transmission clutch housing at approximately 3 o'clock
the numbers should go somethinf like this *******
where as the numbers on a MF5 go like this *******/**
so did i help?:D
FuzzayD
Yes with both of my posts you replied to, i now know what im looking for ^^ cheers
