0081
- Aug 10, 2008
- 493
- 3
- 18
- Location
- Sydney
- VY s m5 supercharged
I apologise iam getting ready for inter cooling and am having trouble with lean outs so was just wanting to have an afpr in place for the up coming mods and psi upgrades.
I just think sometimes there is a lot more why questions asked than helpful answers to the questions asked so my apologies for snapping and all info is muchly appreciated. I did find some modified l67 fuel rails on the thrasher web site which comes with an afpr for $580
This cool mate..
The stock reg should be fine for you I have seen them used with very small pulleys and A2A coolers. The best turner in the country for tuning the L67 motor recommends the stock reg and hates the after market ones.
Yeah they have there place I guess if you need larger fuel lines but until that you don't need one.
If its leaning out there is a problem and a rising rate will likely only mask the problem and not fix it, unless your reg is stuffed that is.....
You have a few options on fuel rails with the l67 motor but what cooler are you going to run and if its an A2A cooler what brand is it.????
you can run YT rails and modifies VS rails off the NA ecotec motor.
what modes have you done so far?? you relay cant/shouldn't go past the 87mm pulley (10psi) without a tune if you have that's likely the cause of your "lean outs"
