The VT brake upgrade is very straight forward, as far as discs, calipers etc go. I have done this mod in my '90 Series 1 VN. The booster and master cylinder change is a little more tricky though.
As for the actual front brakes, you need:
1. The appropriate hub adapters. (I paid $110 each for them.)
2. New wheel bearings. (About $24 a set for Timkens i.e. both sides I think.)
3. VT calipers. (I think I paid $66 a pair for those at the wreckers.)
4. VT front discs and get them machined. (Paid $22 each for those at the wreckers, had never been ground and had plenty of meat on them. Remember, VT discs have far more meat than the standard VN discs and are good for machining about 3 times. Machining cost me $33.)
5. New pads. ($'s vary for what you want.)
6. Longer hoses to the calipers. ($90 a pair.)
7. Suggest strongly going to a 1" master cylinder. This will make the pedal less spongy, as the 15/16" stock cylinder struggles to push enough fluid on the twin piston VT calipers. (Think I paid $66 for a 1" master cylinder and you may as well rekit it while you are at it, about $70 for the kit as I recall.)
Strip the old stuff off and fit up the new stuff, pretty simple. Not necessarily cheap, but a worthwhile upgrade.
I would really like to upgrade to the VT booster and master cylinder. This is a little more complex in that it requires modifying the VN booster mounting bracket, making up an adapter plate, welding the modified bracket to it and modifying the booster rod to the correct length etc. Some modification to the pipework and connections to the master cylinder is also required as the flaring is different (some say there is no need to change the flaring though).
I did have the link to a site where a guy did a "how to" on changing over the booster and cylinder, but he has moved his site and it's not back up as yet. I do have a hard copy print though.
In general, the car pulls up better now than stock, but I do find the pedal still a little too spongy for my liking and at high speed you have to stand on the pedal a bit. But like I say, I reckon the VT booster and master cylinder mod would help out a lot.
You would be wise to check out any insurance implications too I would suggest.
Hope this helps in some way....
