Bush mechanic
- Apr 18, 2019
- 16
- 0
- 1
- Age
- 49
- Location
- Sydney
- Commodore 2002 VX SS
When I first bought this car, I would notice a some movement in the rear end while going through s bends at speed. It felt lose in the back end so I took it to the mechanic and he discovered that the whole rear cradle had been changed before.
Whoever fitted it used smaller cheap Chinese aftermarket bolts. This caused the cradle bolt holes to become elongated due to the constant friction while accelerating and cornering.
He told me the only thing to do is to replace the whole cradle and use genuine bolts. After buying one from a wrecker called "Allfordgm" in Greenacre Sydney and taking it to the mechanic . It turned out to be the wrong one because it didn't have some arms "I think they were camber arms or something".
When I took it back he wouldn't refund me, he said I can trade it for something else but he doesn't give cash back. I did tell him it was a November 2002 VX SS when I bought it and that he gave me the wrong one, but he just refused to listen. I even asked him to make sure it's the right one when I bought it and he said they're all the same, so he ripped me off $280 by giving me a Kenwood head unit in exchange.
I then went to Commwreck in Condell Park Sydney and the nice lady knew right away that the later VX had those extra arms and she only charged me $150 for the whole cradle minus the diff.
After the mechanic fitted the cradle it was spot on until my wife was run off the road by an idiot and she hit a gutter with the left wheel so I went back to Commwerck and bought a left control arm and had to use a big pinch bar to force it in as it wasn't lining up to the cradle mount.
I thought that I fixed it but when I got a wheel alignment the left rear wheel was still 3 degrees out at full adjustment so the tyre started wearing quickly on the inside and the bearing developed a clucking noise which has been getting worse everyday.
The mechanic charged hundreds to fit the last one so I'm gonna to try and do it myself this time because I've run out of money.
Is it a matter of dropping the exhaust and unbolting the cradle, tailshaft, diff, brake lines and fitting the new one on and bleeding the brakes or is there more to it.
