How To Remove Abs Wiring Loom
R
robbie77
Guest
can anyone tell me how to remove the abs wiring loom. I'm having issues with it switching off and i can't for the life of me work out how to get it apart to clean the contacts.
WAGON MAN
Gas Sleeper
North Coast , NSW
VX S2 Berlina Wagon with Phreddied bits.
Here you go Robbie77,
if you look at it from the front, on the right of the plug there is a loop, that is the clip. put a flat head in the loop and slide the clip to the right. the plug will come off then.:thumbsup:
also some useful info
the easiest way to find out if it has a faulty ABS module is
start the car & when the lights come on, is the oil light on?
if so unplug the big connector on the ABS & see if the oil light goes off.
if it does it will need a new ABS module, now there have been a few people say to remove the connector & clean it will fix it, i have never seen this as a long term repair, the fault is a known electronic issue in the module & no amont of cleaning the connector will fix it permanently
Rob
