How to remove Holden VE front right guard?
Flecher
Holden Calais VE
Hi there,
Can anyone help me at how to remove the ve front right guard? I had remove the guard liner clips, and apparently there are another 2 bolts hidden behind the side skirt. How do i remove the side skirt in order to get access the 2 bolts behind it??
Any pic with tutorial will help.
Many thanks~!
Mbro
melb
VS statesman
well, behind the sill cover there is 2 10mm bolts.
you can part relese the sill skirt to get to them but even then its difficult not to break the clips that are holding them on.
to take the sill cover off.
1, remove the aluminium strips on the scuff trims. they are double sided taped on.
2, take the white/black clips out, this will make it so you can take off the scuff trims.
3, take out the screws at the ends of the sill cover.
4, usually i just leaver the sill cover off but this will break the clips.
but yer you get the idea.
good luck.
