How to remove rear bumper vz commodore wagon
rambunctious
Alexandra Headland Qld
VZ Executive Wagon
For this you are best to go to the VZ section (scroll down on left of home page) then go to search on top right and type in remove rear wagon bumper
and you should get something like this
aqgwrecker
western Australia
How to remove rear bumper on a vz commodore wagon
Here are the general steps to remove the rear bumper on a VZ Commodore wagon:
  1. Start by opening the tailgate of the wagon.
  2. Remove the plastic cover on the inside of the tailgate by unscrewing the screws that hold it in place.
  3. Locate the screws that hold the bumper cover to the tailgate. These screws are located on the top edge of the cover, near the corners.
  4. Unscrew the screws with a screwdriver and set them aside in a safe place.
  5. Gently pull the bumper cover away from the tailgate. It should come off easily, but if it's stuck, check for any clips or screws that may be holding it in place.
  6. Once the bumper cover is removed, you will see the actual bumper. Locate the bolts that hold the bumper to the chassis of the car. These are usually located underneath the car, near the rear wheels.
  7. Use a wrench to loosen the bolts and remove them.
  8. Once all the bolts are removed, gently pull the bumper away from the car. It should come off easily.
Remember to be careful while removing the bumper as it can be heavy and awkward to handle. It's also a good idea to have an assistant to help you with the removal process.
