If by 'features' you mean the Enhanced Driver Interface (EDI) then probably not. My senator doesn't have the EDI, and to have it retrofitted involves fitting a module and reprogramming existing HSV-specific software. I can't be certain, but I doubt it would be a similar case of plug and play on non-HSV models.Does anyone know if the HSV Mylink/software can be uploaded into my 2014 Redline so the HSV features can be used
Yep I’ve done some homework and it can’t be done unless the whole unit is changedIf by 'features' you mean the Enhanced Driver Interface (EDI) then probably not. My senator doesn't have the EDI, and to have it retrofitted involves fitting a module and reprogramming existing HSV-specific software. I can't be certain, but I doubt it would be a similar case of plug and play on non-HSV models.
That sounds great! what extra feautres does upgrading the BCM with the HSV options give you?I recently had my BCM and dash upgraded/reprogramed with HSV options and was told by the guy who had to clear a front camera error that he was able to program the EDI into my mylink with the HSV options as long as I fitted the EDI module , so it is possible , I haven't had it done so its all talk
till I have it in my car .
That's the expensive bit, trying to locate an EDI module.I recently had my BCM and dash upgraded/reprogramed with HSV options and was told by the guy who had to clear a front camera error that he was able to program the EDI into my mylink with the HSV options as long as I fitted the EDI module , so it is possible , I haven't had it done so its all talk
