idle issue attention
98NVS
Townsville, QLD
3.8L VS Commodore/Raptor supercharger
My vs idles about 900-950rpm then idles high(2000-2300) then idles down just about to stall out then picks up again.... and so on...
The1
A Memcal a Day Keeps..
QLD
www.eyeit.org
VS V6 Berlina Auto
IAC sounds like it's hunting, is the throttle body and IAC passage clean? No fault codes?
98NVS
Townsville, QLD
Ill check when I get home. Would it have anything to do with idle cable or idle screw??
James39
Gave up on VL's
Newcastle NSW
1995 VS Acclaim & 1992 Holden Barina
98NVS
Townsville, QLD
All fixed it was a vacuum line that came out of the vacuum intake sensor on driver side behind manifold.
Runs smooth as now
98NVS
Townsville, QLD
Thanks for the help ay
