take the top column cover off, the indicator switch off, you will see a small hole in the side of the housing where the barrel is, gently push a pin in this hole while turning the key, you will feel the lock pop out.
there is a small lever in the housing you will need to click down before putting the new lock in, it will click down, dont try to force the new one in.
