Ignition for VN V6 on straight gas
colmiller
I just bought a VN as a drive line donor for my HZ Kingswood project car.
I will be setting this car up to run only on LPG. At this stage the plan is to use Gas Research equipment.
What are my options as far as ignition goes ?
The gearbox is a T700R so that doesnt need computer assistance, I don't need it for fuel metering, the air con etc is Kingswood generation so I don't have to worry about managing that with electronics. Only the spark concerns me.
I would prefer to eliminate the computer altogether if there is a viable alternative.
Doctor Bob
Grandpa
Retired
RG. Colorado & Caravan
you can make the DFI run without anything else but it only runs at 10 degrees flat.
best option is to run the computer, that way the spark maps are all fully programmable
Rob
colmiller
OK Dr Bob thanks for that. Any suggestions where I can find the pin outs I will need to wire up the computer for my limited application.
