jetspin_vn
JetSpin Racing Team
- Nov 13, 2003
- 1,430
- 8
- 0
- Age
- 39
- Location
- Mission Bay, Auckland, New Zealand
- VN GTS
Anyone else had a problem with a chronic miss when the engine is hot, under acceleration that all but goes away above about 2400rpm?
It's like I have lose heaps of bottom end power, you can hear a cylinder missing. When it gets above 2400rpm or so, it comes right. Its a pain the the arse because I do shitloads of driving every day, and having to keep the rev's high is hurting the fuel bill a tad. I don't have anywhere near the time I used to so diagnosing these things always becomes a weekend job.
I doubt its ignition, unless its the CAS. It and the condensor are the only bits I have not replaced. Everything else from the coil right through to the plugs are less than 20,000km old. It's always had a tiny miss on takeoff, but never this bad. I have a sneaking suspicion it could be an injector, but of course I have no way yet to prove it without either changing all 6 of them, or somehow isolating the bad cylinder and replacing the single offending injector.
I'll get to the bottom of it, of this I have no doubt. But if anyone else has had anything similar happen let me know what the cause was, any time/money that can be saved will be wisley invested in drinking
Mike
EDIT: I should add, the ECU is not giving a fault code. Just system pass - this is the cause of my injector theory.
Mike
