PaRaDoX
Because Racecouch...
- Apr 16, 2005
- 3,286
- 34
- 48
- Location
- Melbourne, Victoria
- none
Fazz1977
i hope you like upgrading amplifiers regularly
the vibrations from the sub will reduce the life of the soldier joints in the PCB for the amp, as a result insted of the soldier joints lasting 50 years like they're ment to they might last 1-5 years, seen it happen before, vibrations dont do amps any good alot of people will say "it dosnt matter" and wonder why their amp breaks after like 2 years.. ive had to resoldier joints on a amp that my brother which he was using bolted to his box...
never drill through the firewall, they're is a grommit there anyway as someone pointed out,
running the 12V constant down one side of the car and RCA/12V accessory line down the other will eliminate noise in the line as the 12v current can cause magnetic interfearance as the ammount of current is pretty high....certianly enough to kill you if exposed in the right spot
