exanVZ
- Feb 20, 2011
- 325
- 115
- 43
- Location
- Perth
- VZ Thunder
Changed rotors and pads and can't get the caliper over the new pads. Not able to compress the piston any further, have tried clamps and have opened the bleeder, even tried taking the caliper off completely to make sure there was no pressure preventing it from going further back in. It's the exact same on both sides and the piston does move normally when I pump the brakes, and compresses back to the same point so I don't think it's seized or damaged.
Seems to be about 1mm too thick so either my pads are too thick or the piston needs to go further back in.
The ute has the PBR brakes same as a monaro and SSZ.
Using DBA2021S rotors and Bendix DB1332 pads which all match up with my car (VZ ute).
These are 18mm rotors (correct size) so could these pads be for 16mm rotors?
Pics below, what do you think? Wrong pads or piston issue?
Edit:
Looking up specs online, bendix says 114x58x18mm (L x W x D) and comparing to EBC red or yellow it's 114x58x17mm which would make up the difference in size for the 18mm rotor vs 16mm rotor on other commodore rear brakes although bendix specifically list this as compatible with vz thunder/mondaro/ssz/commodore
Edit:
