PSYKO PHOENIX
AHHHH brain fart
- Nov 15, 2008
- 468
- 3
- 0
- Location
- Auckland, NZ
- 1995 VS Commodore v6 ecotec
So I was replacing the water pump today (95 VS commodore, 3.8 v6) no biggie, going fine, then I had a small problem, I broke a bolt, again no biggie, I unbolted and remove the new water pump, drilled and then removed the broken bolt. sweet back to re installing the pump... before I went to get a replacement bolt and started to re install the pump I decided to clean out the threads of all the other small bolt holes, so I went round 3 and it all went well... then i had one more to go, I was doing the bottom bolt hole when it cracked, I herd a loud cracking nose and at the same time i saw a split spread up the block to just under the hole were the impeller sits and then split across in a T shape... AHHHHHHH FREAKOUT
what I need to know is what to do...
is it fatal?
do I need a new block/engine?
can I use something like stop leak? (its worked on head gaskets before)
can it be welded up and fixed that way?
any ideas or help would be massively appreciated
there's also some gouging to the block from the last water pump that I would like to get fixed too
here are some pics
is it fatal?
here are some pics
