Is this my upper radiator hose that burst?
Mp64
27
VE
Noob alert. Just had my radiator hose burst. Is this my upper or lower hose? Need to know before I order the part as I have a habit of buying incorrect parts lol
I'm gonna assume it's the upper
shane_3800
35
places
vr commo
No image dude
Mp64
27
VE
Oops. Fixed it. Thanks
Not the best photo
BowTie
Jindabyne
Vr vt
The upper attaches near the top of the radiator.
The lower attaches below it.
greenacc
Searching for the billion
VE Berlina
This is why I hate engine covers! The useless things hide the engine making it impossible to see what's going on. If one radiator hose has burst you should probably replace both assuming they're the same age.
krusing
Melbourne, Bayside
Assuming its a V8, by the location of the oil filler, and dipstick.
That Photo is of the Lower one [that is on the drivers side]
The upper one is on the passengers side, and passes under the MAF unit.
Hint: If you do one, you do both !, because you know what is going to happen !
Also, If you do get a top one, before permanently fitting it, make sure it fits correctly and does NOT rub under the MAF,
As I had one where the MAF wore a hole in the top of the hose [where it passes under the MAF]
When I ordered, and received the replacement top hose, I sliced 8mm off the top part of it, so it pulls the hose closer to the radiator, so it then pulls it away from the MAF.
krusing
Melbourne, Bayside
Including the Heater Hoses !
krusing
Melbourne, Bayside
Radiator Hose Part #'s [Mackay Hose's were used as OEM Parts]
Top Radiator Hose Makay CH5472 approx $25
Bottom Radiator Hose Makay CH5473 approx $26
I got mine from Auto Surplus.
Heater Hose Part Numbers -
These are a 2 Piece Hose fittings
Engine to Heater Hose OEM Part # 9228-1853
[Makay CH4227]
Heater Core to Engine Hose OEM Part # 9225-2957
[Mackay CH4201
I got mine from Ferntree Gully Holden, that had some specials at the time
Hope that helps.
Mp64
27
VE
Thanks all.
@krusing thanks a lot for that. Helps a bunch with buying correct parts!
