Issue fitting head unit
CruisinVx
VX Commodore Berlina
Well yesturday I went out, bought a head unit, front speakers, and all the soldering gear... $370 later, I have finally connect all the wires for the head unit (after blowing a fuse by touching the earth with the power). However the particular head unit I got's mounting bracket doesn't fit in the dash, but without the mounting bracket it's a little bit loose even with the fascia thing to cover up the hole that's left (it's only a single din HU).
Hope I've got all the terminology right... still tired af
mpower
made a bit of work for yourself by the sounds of it, push harder it'll fit.
should have just used an aeropro harness, 5 minute job with that.
kangavxss
2002 VX SS
I had same issue as the Alpine cradle was a fraction too big. Just pad the sides of ur unit and inside the hole where it sits with stick on velcro strips. It wont move and easier to take out if needed.
Husky
Pakenham
VXII L67 Berlina Wagon and VEIISSV M6 Sportswagon
Munz
Right Foot Action
Brisbane NTH
VZ Calais LS1 / VL RB30e daily
next time remove the battery terminal when you play with electrics
mpower
I have an Alpine, it fits - PUSH HARDER!!! :D
CruisinVx
Ended uppushing the crap out of it... hitting it with a spanner... then my fist... then back to the spanner... bent it a little bit.... but got it all in there nice and flush.
mpower
seeeee :D :D
oh and btw, I pushed mine in about the midway point (bit wider there) then pushed it up.
shame you didn't aeropro though mate, makes replacing it with the stocko or even a different HU down the track quite literally plug n play.
Dayvo
Because i can
67
South East,Victoria
VE SV6 Series 2
I bought an Aerpro mounting kit and facia and 2 aerpro harnesses had the job done in just over an hour , including hooking up steering wheel controls . Saves a lot of stuffing around and its all plug and play and no soldering .
colourmesilver
Brisvegas
VT1 98 SS 195i 5.0L 304 HSV ENHANCED
Sony's are a different story lol, but at least the holden harness protects your existing wiring
