D
dougie tas
Guest
Have a vn that is giving me greif brought it a week ago a for a steel and now i know why.
I had to put another motor in it and when i did it was not wanting to idle so i put a new fuel pump in (tested no good) then fuel filter and put new plugs in,so now it idles fine but when you give it a rev it gets a major flat spot and stalls unless you pump the guts out of it.
So i took the air intake off and replaced air filter , throttle body is clean as a whistle no air leaks ,havent checked fuel pressure yet or the coil pack is there some thing that might be the problem other than them :b:
PLEASE HELP PEOPLE :cry:
