knock, knock!
Bitemylip
Hey guys,
Was just wondering what part is bad when the engine knocks only when accelerating / pulling the throttle cable
theres no sign of the knock while idling.
On cold start, it also seems to make a weird rattle / unbalanced type noise for a second or two, then again idles fine.
Any help will be appreciated, i will try and get a recording of the sound when i get home.
Thanks
Simone
pjdm1980
Shut up Jr I'm thinkin!
Geelong, Victoria
E1 GTS BUILD NO# 007, GQ Patrol.
Maybe a timing chain, harmonic balancer, bottom end could be a few things.
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
Sounds like an exhaust manifold gasket leaking or a cracked exhaust manifold to me. The noise will be most apparent when accelerating whilst barely discernable at idle.
Zuicider
Banned
Stonedville
Set of thongs
harmonic balancer is there any cracks in the rubber?
TUF UTE
Dave
adelaide
05 VZ SENATOR
failing injector or harmonic balancer
Bitemylip
i've uploaded a vid to youtube
YouTube - buick 3800 knock / rattle
Had a muck around with the car this arvo.
Seems to only make this noise when in park or neutral. I put the car in drive, with hand brake, and brake on, pulled throttle and engine made no noise...
Also had a look at harmonic balancer, looks too be intact and good condition.
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
The rattle in the audio seems about half engine speed and definitely metallic....try removing the serpentine belt just to make sure it's not one of the pulleys - run it for no more than 10 seconds. If the noise is still there with the belt removed try to wobble the harmonic balancer side to side (engine off)...any movement will point to a buggered harmonic balancer. If none of these then it may be getting expensive but keep your fingers crossed. Any other symptoms or has any work been carried out on the engine in the last 3 months?
Bitemylip
just removed belt, still happens with it off - that sucks!
harmonic balancer seems to have no play at all.
It has had a new alternator put on, but other than that, i'm not sure, as i've just recently bought it.
Is it at all weird that it only happens in neutral & park??
vt s
vt s s1
hope its not pre-detonating :(
H1GHROLLR
CHEMICALLY SUPERCHARGED
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
time for a rebuild buddy
