Knock on Cold Startup
vs_commy5506
97 VS BT1 Commodore
Occasionally i get a knock noise when i start up my engine in the morning or afternoon as soon as the engine kicks over? anyone have a clue?
Sickness
VSII Esteem 3.8
I had a bit of a knock when starting about a week after I bought my VS. Ended up having 2 cracked plugs. One idea anyway. check leads and plugs for faults causing missfire.
centy
Vp series 2
oil change first.
check plugs and leads.
Hope like hell it's not the first sign of a worn bottom end.
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
Probably just a bit of piston slap...most Commodores are getting on - but as centy says give it an oil change (unless it's recently had one)
vs_commy5506
97 VS BT1 Commodore
recently has had new plugs and oli change so i dunno, not to worried, if my bottom end is ****ed ill just buy a new ecotech lol
centy
Vp series 2
grab the balancer and try to move the crank up and down a little.
I have seen them bad enough to to do that and still run.
haloeight
42
VS Stato SII L67 S/C V6
Good chance its the engine mounts.
