l67 charger differences
HARVZ-6
Riverton sa
VT spac super6
Okay so iv got a vt super6...
soon ill be looking for a new charger...
to the point iv been told that the newer versions of the l67 had a watercooled charger..
for instance on the vt's theres water jackets leading to the charger... but are blocked off on the charger?
any one know more about this all??
cheers:bow:
vsl67
VS l67 statesman
Ive read the water jackets were used on earlier US L67 versions,but I dont know how accurate that is
HARVZ-6
Riverton sa
VT spac super6
if theyre there id love to use them!
anyone with a l67 knows how friggin hot the charger gets just normal running!
alien
Tullamarine, Vic
03 VY Supercharged 3.8L
HARVZ-6, they dont get that hot if you have good coolant! Mind you, i still wouldn't go touching it after it's been running! But still not as hot as if you didn't have enough coolant, or leaking coolant
HARVZ-6
Riverton sa
VT spac super6
I mean the charger itself baha
motor sits on 83degrees all day =D
coolant wont change how hot the charger is seeing as theres no coolant running through it!
chargedvx6
VY SII HBD Calais L67
No need to upgrade the M90 mate. There are a bunch of affordable mods to do to it that will vastly increase it's efficiency (read lower heat output) and still make it a little torque monster.
IMO if you're doing away with the M90 it would be better to go turbo. M90 has mean bottom end and where it runs out the GT35/40R kicks in
HARVZ-6
Riverton sa
VT spac super6
im not worried about it... i just know that the water gallerys are blocked off..
since im replacing the charger soon because its nearly f**ked wanted to know if there is a new version where these gallerys are open
despite turbo being a wanted option.. to expensive on 1st year apprentice rates lol
it already costs me 100bucks a week in fuel as is
Surfwagon
Sydney/NSW
AMG Mercedes C63 Wagon
Those water passages in the lower inlet manifold are for feeding water up and through the throttle body adapter on US versions.
They can't be used on the Aussie version beacause of the bend passing over the holes where as in the US versions they feed up around the inlet to the SC.
HARVZ-6
Riverton sa
VT spac super6
cheers mate all i needed to know..
much appreciated
chargedvx6
You say your charger is dying? This is very very rare even on high boost set ups. What's the symptoms?
