MYVESSV8
- Nov 28, 2009
- 3,074
- 331
- 83
- Location
- Brisbane/GoldCoast
- VE 6LT M6
common issue for the heater hoses to leak at the fittings, is it leaking from the factory clamps, mine did and a friends (holden service said to just remove old clamps and put on regular style, also said to cut old clamps off, leave connected and just undo your hose clamps put them around do them up clean area and check for leaks once theve been on for a day or two, the organic coolant leaves a bit of crystal behind plus you can smell it, if they leak at the firewall replace with VB-VK heater hoses and re-route at same time away from manifold
