LED h4 bulb headlight
skappascrap
Herp is for the derp.
'02 VY SV8
Cheap is not good.
Good is not cheap.
These bulbs weren't designed for factory Commodore headlights, they will be an eye sore just HID in reflector housings and the light output isn't so great either.
Stick to halogen bulbs.
EYY
VS Statesman
Think of other road users before making any decisions. Also consider the consequences when a blinded driver crashes into you at 100kmph.
VT&VX
90
VX Acclaim
That seller ... 350 negative / neutral in last 12 months feedback
The only reason to go LED is if the light output is better for less power drain on your electrical.
The standard halogen is 60 watts each, so 120 watts total.
Will an LED solution that uses 120 watts total give you better light output...... yes, but only if it is a reasonable quality CREE.
