level 3 dash
Rumbl
= ShAkE AnD bAkE =
campbelltown nsw
VR V6 berlina-VS ss
hey i got a VR and it has a level 3 dash but i think my petrol gauge is stuffed could i use a level 2 dash to check if its the gauge or are the connectors different?
88GreenVN
Next Exit Left
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
Rumbl
= ShAkE AnD bAkE =
campbelltown nsw
VR V6 berlina-VS ss
and where abouts is this located behind the fuel gauge or the bottom section?
88GreenVN
Next Exit Left
Surprise, Arizona
Take the tacho and speedo out and you will be looking right at it.
Rumbl
= ShAkE AnD bAkE =
campbelltown nsw
VR V6 berlina-VS ss
yeh i just found it but the bits you say need soldering looks fine to me
88GreenVN
Next Exit Left
Surprise, Arizona
Hmm - look over all the solder joints - use a pin to slide over the solder - feeling for a crack. Some times it can be the connector where the ribbon goes in. This can be cracked also.
The gauges are almost never the problem - is the DTE working in the cluster - if zero chack the fuel sender connection.
88GreenVN
Next Exit Left
Surprise, Arizona
If you plug the L2 dash in and the fuel gauge works - it will be the cluster. Sorry missed this bit about the L2 cluster fit. Yes it has the same wire config for L2 & L3 gauges.
