dyn4mic said:lowering your car will only make handling worsequote]
how does lowering ur car make handling worse?
Making the car closer to the ground lowers the car centre of gravity making it more stable, plus fitting stiffer springs dosnt make it lean as much around corners, i fitted pedders sports ryders 2in lowr in back and 1.5in lower in front to my calais and the handling improved a whole lot, esp at 110km/h the car dosnt move just sits stable even when cornering, otherwise why are hsv's lower than standard and v8 supercars almost scraping the ground, makes them handle real good
i agree with u about coil overs tho, they're a really good setup.
