lil help
dazastah
No Chaser
VR BT1
hey guys and gals.
i have a 93 5l vr thats shuddering under braking at low speeds. doesnt do it all the time... can really feel it thru the steering wheel, slight wobble side to side. a lil at top speeds too but not bad... any ideas? brakes? trans?
SaGe
VS II S-PAK Manual
get a wheel alignment and see if that make a difference ohterwise u will hav to change ur front bushes. ive got the same problem and im changing my front bushes this weekend and then getting a wheel alignment. once its done it should feel like a new car
scorpio
VR CALAIS 5L HSV ENHANCED
maybe tailshaft?
SaGe
VS II S-PAK Manual
a tailshaft vibration is usally constant at the same speed while travelling like at 60kmh u will feel vibrations but not when ur braking at different speeds
WILD VR CLUBBY
lack of licence
Melborne
2004 vy s
could also be rotors
SaGe
VS II S-PAK Manual
yea that too, if ur rotors are warped and ur brake pads r wearing fast theyll screach and vibrate
elmoticus
VR Ute
Most likely your rotors need machining or if undersize they will need replacing
dazastah
No Chaser
VR BT1
cheers fellas
go with the brushes and wheel alignment and brake upgrade was on the cards anywayz...
