LLT engine Pre-cat (upstream) O2 Sensors
Hamish237
27
VE Commodore SV6 Wagon
Trying to find the correct pre-cat o2 sensors for my 2010 Sportswagon with the LLT engine, and was incorrectly sold post-cat o2 sensors.
Since then I have found so many sellers selling the post-cat sensor and a pre-cat sensor.
Does anybody know the correct part number or model for the pre-cat sensor for the LLT engine?
Attached is the correct female and male connections.
07GTS
Australia
VEGTS BUILT BLOWN E85
EGO-561 is what shows up in my search pre cat they look the same as the post cat just different length, plugs look the same the tang at the top goes in the gap on the plug and the other side is the clip
Hamish237
27
Same here, but it isn’t correct
The post-cat connectors are black with the guides in different places. Attached are photos of post-cat connector (black connector) and pre-cat connector (grey connector) for comparison.
07GTS
Australia
the number i listed is for pre cat the post cat is is different number so if u search that no. see if it's right
