Loss of water
Boblet
72
marburg
2008 ve omega wago
Hi all, just wonder8ng why I have to keep topping up the radiator on my 08 v6 ve. Every few days I check it and it always needs topping up. The header tank(overflow tank) is always full, no splits in the hose, just dosent want to suck back the water. Had the same problem with my vy and vz as well. Thank you.
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Try a new, genuine radiator cap.
Boblet
72
marburg
2008 ve omega wago
Have one already and the problem is still there.
gossie
Gold Coast.
VE International 3.6L
Pressure test and use the correct RED coolant.
hademall
Donating Member
66
VF CALAIS WAGON
I had a 1986 Falcon wagon from new. It lost water and I couldn’t work out why. After eighteen months old I took it to a radiator specialist and he discovered a very small leak in the radiator, which only leaked when the engine got really hot. The leak came out as steam and was not detectable under normal circumstances. The guy said it was probably due to a manufacturing fault in the original radiator.
Boblet
72
marburg
2008 ve omega wago
Thanks everyone, I will get a pressure test done and go from there.
Boblet
72
marburg
2008 ve omega wago
Well I seem to have fixed my problem. Found out my new genuine radiator cap was one from an auto accessory shop. Bought a new genuine cap and so far ( 4days) all seems well. The non standard cap pressure is 125kpa where as the genuine cap has a pressure of 140kpa. No leaks from a pressure test also so it seems the non genuine cap was to blame. Thanks to all who offered advice.
VS_Pete
Donating Member
Thanks for letting us know mate:)
  • Like
Reactions: Lex
