Shen Long
- Sep 27, 2011
- 962
- 359
- 63
- Location
- Roxby Downs
- WH Caprice 5.7L
Go to AutoBarn & ask for high pressure fuel clamps & some EFI fuel hose (replace that dried out hose)Theres the engine bay. Mechanic said some have filters some dont...LPG filters wet/dry...so I dont know what I have .
Car info says :
HOLDEN COMMODORE LPG Auto VE 08/2006~08/2011 4 Door Sedan RWD LPG 3.6 Litre, LW2 (HN) V6 24v DOHC VVT MPFI {175kW}
I dont know if its factory or aftermarket LPG but its DUAL FUEL car.
One big mindfuk: See those relays/injectors , whatever they are on top of the engine with hoses going in it from left and right? When I lift front hose a bit to see whats underheath I hear HISSSSssss and can smell LPG. Pretty sure thats not safe. When left alone it doesnt HISSSSsss. Maybe hose or hose clamp gives way when lifted up? Damn. Exactly where you see I applied some silicone so rty and see if itll fix it or show the source of the leak.
Offtopic:
I want to do the oil change as well as Im doing few things to the car so why not? lol. BUT I only have that factory jack thats for changing wheels. Can I use it to lift the car from the front somewhere and have enough tilt/elevation to change the engine oil?
Tnx
**take a piece with you to get the right size**
Those clamps could be for water/radiator purposes only & aren’t capable of withstanding the LPG pressure &/or hose is cracked/worn
P.S.
eBay Link Dual Fuel Type LPG Filter
