LS1 Injector question
Heffer_Slayer
VX Berlina
Hey all. Yet another thread, with another question :p
I am pretty sure the reason my car is not firing straight away after letting sit for a little bit is due to the injectors.
I still have the original injectors from memory (they are black ones). Orings are worn, I recken they are leaking too, anyway to easily verify if they are?
If i change them, will i need to retune the car? Do i need to get the same identical ones? Or can i go aftermarket?
Where is a good place to grab a new set of fuel injectors?
They are stock as far as I know of.
Munz
Right Foot Action
Brisbane NTH
VZ Calais LS1 / VL RB30e daily
How's your battery? Mine was doing the same until I replaced the battery
If it is injectors and you replace with oem spec you won't need a retune. They are easy enough to remove and unless there are no physical sign of leakage you could have them checked by someone that cleans injectors. Personally if they're faulty I would replace with brand new ones
Are we talking VT or VX LS1?
Heffer_Slayer
VX Berlina
Battery seems fine, the car cranks over fast like it should.
All the orings look stuffed on my injectors, I had them out over the weekend while changing my knock sensor, and pretty sure they were dripping a little bit of fuel (only one drop) with them out of the car.
I might actually take the rail/injectors out while keeping it connected to the fuel line and prime the pump to see if it leaks.
The rear passanger side injector had a residue around where it sits.
Also i noticed on the intake manifold, there are little grooves which looks like a guide to where the injectors are meant to sit. Though my injectors have to guides to put them in...is this normal?
Its a VX LS1 Berlina
