Ls1 manifold
Logz55
30
Kadina
Vt ss 5.7
Hey just wondering if a ls6 manifold will do any difference compared to the old style is in worth the #### around cheers
Munz
Right Foot Action
Brisbane NTH
VZ Calais LS1 / VL RB30e daily
around 10rwkw difference. If you can pick one up cheap enough they're easy enough to swap
Logz55
30
Kadina
Vt ss 5.7
That's not bad I can get one for bowt 150 200 is that too much?
uniacidz
Harden the Frak Up
Sideneee
VE Berlina
Hmmm interesting
Darcon666
Evil is always around you
At home
www.gfy.com
The Wife
Might just add that seeing you have a HSV and it's a VXII.... It should have the LS6 manifold already.
You can check by looking at the middle of the manifold on the passenger side and look at the serial number.
LS1 S/N# 12560688. & 12556333.
LS6 S/N# 12573572. & 88894339 - 12561184 & 12561182
ConstantVelocity
ACT
VTII SS M6
The fins on the bottom will need grinding down to clear the early-LS1 coolant pipe setup (vents to all 4 corners of the heads). Or you can replace with the later setup that only vents the front corners, but hard to buy them locally. Seems to be worth 5-10 rwkw depending on other mods, stockish motor will be at the lower end. Worthwhile if you can pick one up cheap (seen em go for $50ish on ebay).
