Mace TB on VP 5ltr
04VYSS
Perth W.A.
04 VY SS
So spending the last few days trawling through the copious amounts of threads here I've seen nothing specific to my question / topic..... so here goes....
Has anyone here bought and fitted the MACE 70mm TB to a VP 304 5ltr ?? - Any suggestions as to the ease of fitting.. I have referred to MACE's website looking at the fitting instructions but they are for the V6.
So, does anyone here have any feedback or suggestions as far as removal / fitting the TB for the 5ltr.... any suggestions or help is appreciated.
MACE
93SIIVP5LTR,
The main "tricky" differences with the install from memory are the injector rail covers have to come off along with the throttle body cover, which has three wing nuts underneath. You also have a crankcase rubber hose which going into the throttle body which is a little bit more difficult to throttle body then on the V6's but that all the differences are really. Unless you have cruise control then you don't have to change the throttle linkage.
Hope this helps.
Steve
04VYSS
Perth W.A.
04 VY SS
Thanks Steve, that will help a lot mate :spot on:
MACE
If you still get stuck, I just found a heap of step by step pics of the TB installation for 5L on the ol hard drive :)
The purpose of these pics are to be used eventually to write up fitting instructions for the job.
If you have any more questions please don't hesitate to ask
Steve
04VYSS
Perth W.A.
04 VY SS
Should be pretty straight forward but I'll give you a burl if I get stock :hmmm:, uh I mean stuck.
Cheers Steve!! :beer chug:
