mates vc woes
JD
Donating Member
34
Deep South, SA
www.ccgm.au.tt
1.6L Turbo Holden Croooooooooooze
my mate just bought a vc wagon dual fuel auto 202
now today it will not stay running on gas ( just conks out when you lift off the acclerator ) and when you a revving it it sounds like the engine is missing.
on petrol however it will rev at 2000rpm when idling and when revving it it sounds fine ( no miss )
what could be wrong with it???
1vngal
34
North Tassie
'Ruby' 1991 VN Exec & '98 Proton M21 Coupe
Some sort of blockage in the gas system maybe?
craigvk
Banned
VK 5L Calais
Try adjusting the idle screw on the mixer to get it to its highest idle point. Take off the mixer and inspect the diaphragm for wear or loose parts like the spring or screws. Sounds like the mixer isn't doing its job. The converter sounds to be ok, but take off the gas hose on the mixer, and while cranking, see what sort of gas flow is coming out. No smoking or KaBoom!
Make sure the radiator has plenty of fluid in it.
Outlaw Torn
33
Opononi, NZ
91 FORD EA Falcon (So sue me)
Also another point to check, on the regulator there should be a drain plug similar to what the motors sump plug looks like. take the car for a good burn until the engine is hot and then take the plug out of the regulator. There may be a fair bit of gooey brown crap come out.
ps, it would pay to turn the gas off at the tank first just in case.
VLCrewman
VB\VL Crewman
This is probly an incredibly stupid question, but did u run the carby out of fuel before you flicked over to gas?
craigvk
Banned
VK 5L Calais
That's a good point. Usually it would cough and splatter and run like a complete barge if you didn't. Floods the carb.
JD
Donating Member
34
Deep South, SA
www.ccgm.au.tt
it was on gas when he bought it because the petrol cap broke
he first swichted it over to petrol when he was having probs with the gas.
BTW he fixed the problem with the petrol ( sticking accelertor cable )
still idles a little high though.
it wont run on gas still but i will suggest he look at those things u guys mentioned
it does need a new gasket on the carby could that be a problem as well?
thanks a heap.
craigvk
Banned
VK 5L Calais
If the gasket is a problem, there would be a vacuum leak. You would notice the car struggling with throttle, like lack of power etc if there was a vacuum leak. Replace the gasket if it's suspect.
Now the idle. On the left hand side of the engine bay (kerb side), put your head under the mixer and you should see a medium size phillips head screw on the carb with a point on the end of it and the screw should be pressed up against a cam which has several different stages on it. With the car running, adjust the idle screw by turning it anti clockwise until the car idles at a nice speed. The high idle when warming up should be around 1000-1200 rpm. In drive when the car is warm should be around 650-700 and in neutral/park should be around 800-850 rpm. Adjust the idle screw when the car is fully warm. i.e: Driven for 3-4 km or idled for 10-15 minutes.
Hope this helps.
atrail308
RIP King of the Mountain
southside adelaide
V8 VH SL/E 308
if it idles too high on petrol, turn it down on the carby...
Tree cutter
Tree cutter
Mt Gambier SA
VX Calais SuperchargedV6
Replace the carby gasket before adjusting the idle. The high idle speed could be caused from sucking air in through the faulty gasket. The gasket could also be causing your gas problems if you are loosing a lot of vaccum which will make it run lean.
