Mate
do you realise what it takes to run an 11 sec quarter
Tell me what your car weighs
If say it weighs 3000 puonds then to do and 11.5 sec quarter u will need 350 hp.
To get 350 hp from your car and you have to ask what it will cost and take.
Then i dont wanna be rude but you cant afford it
Take a 308 for instance
to cut and 11 you need flat top pistons, yella terra heads or Brock B Casts, mild hyd cam, genie tri ys and torker manifold and a rebuilt qaudrajet.
Doesnt sound much i Know but that is 308 cubes not 202
To be even close you will need to stroke yours too say 223 cubes
add a good set of rods and some acl hyperuetetic pistons, find a yella terra head and get that to Eddie Jones at The Head Stud for some port and valve work and to set the springs up. Then a solid cam from someone like CROW. Then maybe some triple webbers or SU's. Then an ignition system and extractors.
I reckon you would be loooking at 3 or 4 grand for the engine plus another 1500 for the carbs.
Or you could maybe go the turbo route but that will cost you more.
