digisol
- Oct 6, 2005
- 537
- 5
- 0
- Location
- Central QLD
- Toyota Landcruiser
Likely the vacum line is not connected to the correct spot or there is a giant leak, remove the line and use a finger, no suction, connection problems, there will also be a very tiny restrictor placed in the hose at the guage end (comes with guage), so if the ID of the hose is 1/4" the actual diameter the guage gets would be a tiny .010" if that.
Without the restrictor it won't work well if at all, it will bounce all over the place with the rise and fall of the piston suction.
The pic is just showing a representation, every engine will have different amounts of vacum, so long as when with no throttle down hill it shows max vacum, and up hill with throttle open little or no vacum.
Either way it should connect on the manifold somewhere there is a take off point, or under the t/b, it should have more than just a little vacum, it may need a T piece in a current hose.
