V
vnberlwagon
Guest
Does anyone know why Holden hasn't released a multi-valve V8? Is the current Ford "Boss" engine better or technically advanced than Holden current engines?
vnberlwagon said:Does anyone know why Holden hasn't released a multi-valve V8? Is the current Ford "Boss" engine better or technically advanced than Holden current engines?
1991_Vn2nV said:Pushrod isn't necessarily a bad thing. Its technology thats been tested and proven over many decades. Look at the new alloytec engine, in comparison to the Ecotec its technologically much more advanced, but not neccessarily a better engine. Pushrod engines don't tend to rev as high as a OHC engines, but that seems to be the problem with the new Alloytecs which get their max power at 6500rpm which means you really have to rev the guts out of them and actually redline the engine to get maximum power, unlike the pushrod engine on my VN for instance that gets max power at 4800rpm
vztrt said:OHC isn't exactly a new technology, as the first OHC engine was produced around the start of the 20th century. Pushrods if I'm not mistaken are a cheaper motor to produce also easier to engineer.
is there realy a point small gains in hpvnberlwagon said:Does anyone know why Holden hasn't released a multi-valve V8? Is the current Ford "Boss" engine better or technically advanced than Holden current engines?
I think you're right, after reading what other members have said it seems that all other car manufacturers are doing is using technical jargon to sell their vehicles, much the same as what Holden and Ford do when they say their cars can achieve 300kw's. What speed and rev tally has to be achieved for that 300kw's to be reached.:driving:burnz said:is there realy a point small gains in hp
all lost on restictive intake and exhaust
some times i think it's just braging right's to sell a car
vt1538 said:You can still multi valve an engine with pushrods. They just need a bridge running between the valve tips.
