My 1999 VT Berlina - Holden_4aw_lyfe
holden_4aw_lyfe
Tsu Tsu Tsu Tsu
Twin Turbo Stroked 4.2LT VT Berlina
**OLD, NEW MORE REVISED DETAILS AND PICTURES COMING SOON!!**
My 1997 VT Berlina Series 1 V6 3.8
SAND PEARL MK2.
Engine/Transmission:
- Block Decked, Honed, Line Bored, Balanced and Blueprinted W/ Compression 8.3.1
- Pacemaker Extractors
- 2.5" Custom Stright Exhaust With Dual Exhaust Chrome Tip
- Metalcat High Flow Cat 200CPSI
- Hedman Muffler 24" Straight
- Mace Engineering Custom Plenum Spacer 17mm
- Mace Engineering Custom Cold Air Inlet Manifold Spacer 25mm
- Mace Engineering Custom Bored Out And Polished Throttle Body 69mm
- Mace Engineering Custom 85mm Mass Airflow Meter
- Yella Terra 1.7.1 Ultra Lite Roller Rockers
- 4" Pod Filter
- US Motor Works Professional Series Water Pump
- Custom Ported & Polished Plenum Cover
- Custom Ported & Polished Manifold
- Custom Polished Fuel Rails
- Transgo Stage 2 Shift Kit
- New Transmission
- Corvette Servo
- Billet Rocker Cap
- Custom Polished Fuse Cover
- Top Gun 10mm Ignition Leads
- MSD Ignition 8224 Coil Packs
- B&M Line Locking System
- Fabricated Aluminium Power Steering Reserviour
- Polished Rocker Covers
- Fabricated Polished Aluminium Fuse Box Cover
- Fabricated Billet Rocker Cover Cap
- Fabricated Polished Aluminium Strut Tops
- Fabricated Polished Aluminium ABS Cover
- Fabricated Cruise Control Cover
- 8" LSD 28 Spline Diff With Borg Warner 3.9" Diff Gears
- Detriot Tru Track Lockup System
- COMP Cams Agressive Stage 3 Cam
- C.O.M.E Racing 4.2L Stroker Kit W/ "H" Beam Conrods
- Rollmaster Double Row Timing Chain
- Cast Nodular Iron Crank
- Powerbond 5% SFI Overdrive Harmonic Balancer
- Mace Engineering Ported Aluminium Heads
- Custom Oil Pump
- King Bearing Kit
- 3500 RPM TCL Strengthened High Stall Converter
- ARP Head Stud Bolt Kit
- ARP Mains Stud Bolt Kit
- Crow Cams Roller Lifters
- Bosch Platinum Fusion Spark Plugs
- ARP Flex Plate Bolts
- K&N High Performance Oil Filter
- Turbosmart FPR800 Fuel Regulator
- Clarko's Aluminium Pulley's
- ACL Race Gasket Set
- 40 Thou Cometic Race Head Gaskets
- Custom Turbo Manifolds
- 2x Garrett T28 Turbos
- 600x300x76 Intercooler With Pipes, Clamps and Silicone Bends
- Boost Controller
- Turbosmart Supersonic Blow Off Valve x2
- Stainless Braided Water Lines
- Oil Lines
- TTT Performance Engineering Engine Mounts
- 80lb Siemens Deka Injectors
- ASR Street Comp High Volume Custom Oil Pan
- 4 Core NT Perofmrance Aluminium Radiator
- Aircon Deleted
- Silicone Radiator Hoses
Suspension:
- King Spring SSL Suspension SOON TO HAVE HSD COILOVERS
Interior/ Exterior:
- Custom Headlights Monaro Look-A-Like
- 6000k Xenon HID Conversion Kit
- 19" B&W Wheels
- VX SS Gunmetal Grey Dash
- VZ SS Chrome Air Vents
- Full LED Blue Dash Conversion
- Full Blue LED Interior Lighting Conversion
- 4x Under Seat Blue LED's
- Full White LED's in Number Plate And Wipers
- Clear White Reverse Lights
- Genuine HSV Custom Painted Rear Boot Garnish Tungsten Mica
- Chrome Bonnet Struts
- Full Under Car Neons
Stereo:
- 2X Rockford Fosgate P3D212 12" Subs
- Rockford Fosgate T1500 Power Mono Block Amp
- Rockford Fosgate T400 Power Amp
- MB Quart 6" Splits At Front
- German Maestro Discus Series 6X9 Rear
- Optima Yellowtop Dry-Cell Battery
- Eclipse AVN726EA Head Unit
- Mitsubishi 120Amp Alternator
- Rockford Fosgate 10 Farad Capacitor
NEW PICS OF FINAL PRODUCT SOON
Sphinx
O.G.
caught in a mosh
VX Calais II LS1
Looks pretty good. But I'd be removing all the badges except for the HSV on the rear garnish as it looks odd with the HSV one right below the Holden one. Much drone with the 3.5 inch exhaust? Oh, you could do with a few more unit stickers too :D
hsvpunk
volunteer firefighter
Mornington, Vic
vy ss II M6
hmm looks alright. I looked at a gen3 in this colour a while ago.
Unit... right.....
As mr sphinx has said.
Also, where in melb ya from?
holden_4aw_lyfe
Tsu Tsu Tsu Tsu
haha im a big UNIT fan lol. yeh all the badges are gonna be removed, its getting a respray and all the dints knocked out of it so when i get that done ill remove em then. Im from Sunbury lol :) yehhh the exhaust sounds good, its needs to sound deeper tho haha. When i put the pacemakers in and the chip itll sound and go better :) well should haha
Jamesmaier
Vt Executive
does it lose any power through the 3.5" because you would think so being that large? would sound tough though
VX commo 02
purchasing S/C VX!!!!
35
Adelaide, SA
VX Commodore S2 & VX S/C S pack
looks sick man loving the rims :)
Adriianz
GTS
cery nice. id go with debadging entire car except for the HSV badge too. tint windows. and personally if you have the time/money. i think chrome windows/front mirrors/door handels would looks absolutely awesome!!
holden_4aw_lyfe
Tsu Tsu Tsu Tsu
it does sound good, its got a clean note to it...i was actually suprised when i first heard it lol. the whole car is going to be chrome, the theme is chrome so hopefully a lot of it will go on. Just bought a 6000K Xenon kit for it and custom aftermarket headlights. should look sick :p
jarrad09
Vt 5sp S
Vt S Manual V6
what sort of chip are you putting in? Car looks nice too..
Dum*P*ster
Moist
Queensland
VE SV6 SIDI
looks nice !:)
But , IMO.. I dont like the Unit Stickers :(
pics of engine bay pleassssseee??? :yeah::yeah:
