teastpilot
testpilot
- May 22, 2008
- 12
- 0
- 0
- VK vacationer / VP berlina
the rear was identical in every way, just use the VP "D" bushes to accomodate the slightly larger dia. bar (front and rear).
The front of the VP uses a mount off the side of the strut and the links go down to the swaybar eyelet, the sway bars on the ground together were within 40mm or so eyelet to eyelet and the same overall shape. The VK uses the links up to the swaybar eyelt from the lower control arm.
So it was just a simple matter of swapping the bar over to the VK linkage setup and tossing away the VP linkages, i checked it for suspension travel clearances and no hits rubs or klunks, all sweet, really noticable on the road sits much flatter and more controlled, in short probably the cheapest and most effective mod i did, without having to resort to aftermarket options.
Interestingly the VP's lower control arms had holes to make use of the lower mounting system. i think i gained about 3-4mm in thickness in both bars (the rear possibly more) by using the VP's and its certainly noticable on the road. I think the VK was 23-24mm std on the front and the VP front was about 27mm, i didnt measure the rears but its visible, i still have em so i can measure em tomorrow n repost.
An yeh, the steering wheel was the second thing i did to the car.
