Thats not such a bad idea.hinterland said:looking very neat good job.have you had any thoughts of making the link arm so that only one butterfly opens say to half throtle then the other one comes on ,might make for better drivability when just cruising round town.
maybe something like ths so dits cam at certain positionchevy_big_block_bro said:Thats not such a bad idea.
Somehow have it on a spring that open slowly at first then if i want can open to WOT if needed.
Might need some help on that though
The thought of a spring tensioning up to move the second butterfly did cross my mind but once again there's the problem with the throttle possition switch reading the right measurment if the second TB doesn't open up like the first one.MBS206 said:The unit I'm building up, will be setup so that the second T/B opens up once the first hits 25% throttle (Will be adjustable though for performance sake!)
Was originally going to change the length of arm that the throttle body connects on to, and run a second cable to it... But no, That'd be the hard way!
I'm going to run a connecting bar across, how most people do, but have the bar a bit too long, slip a spring over it, then put a nylon lock nut down it, so the bar does move through all throttle movements, but the actual butterfly won't move until the spring is fully compressed.
