Nackerz
Rollin
- Jul 10, 2009
- 1,132
- 2
- 0
- Location
- Victoria
- 2 n/a vl's 1 twin turbo vl vn ss vy sv8
Nickname: Nackerz
Model: 1990 Holden VN Berlina Wagon
Colour: Silver
Bodykit: None
Engine Type: Injected 304
Engine Mods: Unsure, Has injectors and is meant to have a cam
Power: Unsure
Exhaust: Extractors
Gearbox: Turbo 700
Diff: Borgwarner, Have to check gears, Non lsd
Brakes: V8 Disc brakes all round
Suspension: Pedders in rear
Wheels/Tyres: Crappy 5 spokers
Interior: VQ Stato front seats
Stereo: None
Build Period: Started Saturday 20/11/2010
Cost: Swapped it for the vk, Only cost for trailer hire and fuel
Hey guys and girls,
Well I swapped my vk 5 litre for the wags. Needed more of a family car.
The guy I got it off had to change the motor as the rings were screwed, so he did that. While he changed the motor, when it was time to bolt the gearbox to the motor, he had put the torque convertor onto the flywheel first. And as you know, yep he screwed the pump big time!!
So I had to pick her up on the trailer. Did that on friday, Saturday the fun began....Pulled the gearbox out of her, and the pump out. Found that he screwed it pretty good.
So why I have it out, I'm looking at putting some goodies into her.... This is what I came up with while I was looking for a replacement pump;
13 Vane Pump upgrade Kit Hi-Perf $111 Posted
13 Vane Pump Upgrade Kit Suit TH700 4L60 4L60E Hi-Perf (eBay item 350321485704 end time 22-Nov-10 20:27:55 AEDST) : Cars, Bikes, Boats
Transgo High rpm pump kit $47.99 Posted
TRANSGO T700 4L60E HIGH RPM PUMP KIT COMMODORE AUTO (eBay item 250727321838 end time 22-Nov-10 21:24:43 AEDST) : Cars, Bikes, Boats
Corvette servo piston $42.45 Posted
Corvette Servo Piston Turbo 700 TH700 T700 4L60 4L60E (eBay item 350325850724 end time 03-Dec-10 18:02:53 AEDST) : Cars, Bikes, Boats
Transgo Shift Kit Stage 2 or 3 $214.30 Posted
RECOMMENDED PARTS TO ADD TO THIS KIT
Servos: Corvette 2nd Servo (Firm Shift).........^^^^ Have listed this one up top ^^^^....... Billet 2nd Servo (Super Hard Shift) Billet 4th Servo (Street, Towing, Race, Low Diff Gears a must).
Accumulator Pistons: FWD, 2nd & 3rd Piston OEM Alloy, FWD 2nd & 3rd Pinless Alloy Piston.
Valve Body Plates: TransGo Performance Plate (81-93).
Electronics: 4th Gear Full time Lockup Kit (For No ECU Installations).
Transmission Filter (88-93) and Sump Gasket.
Holden Commodores Shift Kit Turbo 700 VN to VP V6 & V8 (eBay item 350313842620 end time 03-Dec-10 19:13:07 AEDST) : Cars, Bikes, Boats
Rebuild kit for all gaskets and orings???? $83.75
Automatic Transmission Rebuild Kit TH700 4L60 (88-93) (eBay item 150489826777 end time 05-Dec-10 12:14:02 AEDST) : Cars, Bikes, Boats
Total price for this ^^^ $499.49
I would also get new gaskets and trans filter....
This list is what I came up quickly on what to do:
Well the injectors sorta look like these, but they are blueish.
BOSCH 968 42lb EV6 FUEL INJECTORS LS1 LS2 XR8 VN-T HSV (eBay item 360290948465 end time 23-Nov-10 20:00:58 AEDST) : Cars, Bikes, Boats
Also thinking about getting a kit for it maybe....What do you guys think of these??
VX HSV Clubsport bumper body kit -Holden VN/VG/VP Wagon (eBay item 290498499041 end time 20-Nov-10 18:21:23 AEDST) : Cars, Bikes, Boats
Well the gearbox is out!! There is broken/cross threaded bolts. Also the bellhousing is cracked and has a bit broken out of it....And the torque convertor was stuck on there good, I had to leaver it off! So the pump is screwed for sure.
.......More updates to come guys!!
Well hello all again. I have yet another update for you all...
Been working on the thing all day!!!
Ok so I found out this:
An external tranny cooler aswell as the radiator
Has some sort of fuel control, see pics
Ok so after I had pulled the tranny out and pulled the pump apart, I thought to myself, I will do other stuff in the meantime while I chase the bits and pieces that I need to fix the gearbox pump.
Stuff I have been doing:
Most of the gas system out
Checked the part No. on the injectors....Part No. 0280155777
Found out about the tranny cooler and fuel control
Checked what speakers it had: Pioneer 6x9's in rear and little Sony speakers in the dash
Nackerz
Ok now some pics for you all....
All of these pics are of how I got the car....
Nickname: Nackerz
Colour: Silver
Bodykit: None
Power: Unsure
Exhaust: Extractors
Gearbox: Turbo 700
Stereo: None
Hey guys and girls,
Fix Gearbox
Remove gas system as it's not a BBQ
Fix rear plastic (Couple broken, nothing major tho)
Fix rear left door/quarter (Was side swiped, Nothing big tho)
Fix squeaky belts
Fix exhaust leak (Tiny pin hole in the rear)
Adjust Handbrake
Fit Airbox/Pod filter
Secure cold air pipe
Check Brakes/rotors
Change tyres (RWC)
Check central locking (Right Rear door not working)
Look at tail gate lock (Cant lock it with the key)
Secure battery (Nothing as I kept battery from vk and just sat it in there. Bolt and plate there for it)
Check lights for RWC
New headlights (Right side not sitting right and left has a small hole. Better of just getting new ones)
Regas the aircon
Move spare wheel into the section where it belongs (After remove donut tank for gas)
Check height of vehicle (100mm from lowest point is the lowest legal height) RWC
Exhaust manifold gaskets (New, have to remove to pull the gearbox out)
Change rear left door trim (Missing a section, but have complete door trim there, came with car)
Fix paint fade on bonnet and roof
Find out what injectors they are, as there not stock ones.
Told it has a cam (Sounds like it too)
And that just about wraps it up! Just doing a complete RWC on it, so when I take it there they pass it
Also have to fit a stereo to it.
Nackerz
