cpbait
- Jul 8, 2006
- 1,075
- 7
- 0
- vy ss commodore 5.7ltr
you'll be able to change the T/B to the older gen III with with cable but you have to change the wiring, (mine is getting changed next week) otherwise im sure u can port out your original if you don't want to
yeh with that cam ive seen a few ppl make around the 290rwkw figure for such a baby cam it can pull quite well
Wow that sounds like some good numbers, what lift is that 220/220 112 cam?
iv got a crow cam 218/224 114 cam at home to go in my vy ss, been told it wont pull much as its only .527" lift on exhaust and inlet and will need a small exhaust like tri-y's rather than 4-1's and twin 2.5" to pull more down low, so was going to rebuild my motor any way and put a bigger cam in.
And as was going to do some head work to go with was told this would be useless on a small cam like that as well.
seen results from same cam in the states with bigger valves and porting off the heads making good power though.
