mike0169 said:
i'v just bought a neon windscreen washer and was just wondering how would i hook it up to my parklamp wire?
hey, ive wired up my brothers and mine, the best way to do it is to buy a flick switch and run the wires from the washers then run the leads from the other end of the switch to the battery
washers ------>switch<------battery
make sure you solder all connections and cover them with elec tape to prevent oxidation of the connection
the tricky part is getting the switch inside the car, the easiest way is to either run it through the grommit or through the side panel on the drivers side and in through the door, i mounted mine next to the bonnet release switch with a missile toggle so you can easily turn it off with your foot so you dont get busted, they're apparently a "distraction"
anyway hopes this sheds some light
