New billet tailshaft couplings in but vibrating real bad
Crowie17
24
2006 VZ SS Thunder
Hi all, just put some billet tail shaft couplings in my vz ss ute, but half through my drive home it began to shake and shudder a lot while rolling, goes away alittle under load, I’m thinking it could be I didn’t put the tail shaft back in right, any tricks to see how to get it back to normal ? Cheers
_R_J_K_
Zenki S14
When you take any part of the tailshaft out you're supposed to keep it in alignment with the rest of the tailshaft (usually people draw a white line over the two connecting faces of each piece). Rotate one half of the tail shaft until the vibration goes away, and make sure it's bolted to the car properly - your description makes it sound like one side of a bracket might be loose.
LYV Y R
60
Emerald
VY2 SS Ute
I just had the same thing.
Everything looks seated and true.
Vibrate on coast down
Suspect they are carntz of things, putting OEM back in.
Fu Manchu
Get Off Your Phone When You’re Driving.
Western Australia
Kia Sorrento, VZ Crewman, VZ Cross 8 (VE Calais)
They are probably now having any wear in the centre bearing accentuated. Also improper alignment of the drive shaft?
shane_3800
places
vr commo
They're rubber for a reason, when the rear cradle bushes load up the diff will be out of line to the transmission, now you have one uni joint that has no twin to even out the acceleration pulses, thus giving vibration which is what the rubber dampens.
LYV Y R
60
Emerald
VY2 SS Ute
After exhaust off tailshaft out 3 times, l found the inner diameter of the crush tubes were bigger than oem.
OEM neat on bolt, these have clearance.
Means not pinned, get off centre, vibrate.
Not fit for purpose or sale.
L
losh1971
Guest
Rubber couplings have been fine for me too. They seem to handle a fair bit of WOT standing starts. They don't do so well with burnouts, I'm told. I'm not sure about clutch dumps, as I've not done many, if any of those.
