CRS kit is $1950, all you need is someone that is willing to do a bit of work for you, throttlebody needs to be relocated, the blower mountings stay the same all that needs to be done is to move the TB from where it is make up another pipe that will bolt onto the plennum and matches up close to the blower intake then use the sleave to join. Now grab the intake that goes to ur airfilter and you will need to make up short pipe to weld to the intake with a bracket on the other side that matches the back of the TB to bolt up to, giving you the TB befor the blower,throttle cable needs to reach round the left side of the engine around the front to the new TB location. You will also need to lengthen the air sens wires to now reach,the Ecotec you can use a 60ohm resistor in the air sens to fool the ecu into running at 2deg which basiclly makes it dump more fuel in all time like when you 1st start up in morns it does that to protect the engine until it warms up, with the VR buick engine they do not have this sensor so not sure bout fuel issues, you may HAVE to get it chipped with bigger injects regardless,Hardest part will be fabricating the bracket to match the TB which will be the same for the plennum. also needs to dyno to tune it as it may run lean top end.....widowmaker race engines can do this install for round $1500 plus the kit, all in all fairly cheap upgrade with insane results.....this info came to me via Powerup who is very knowledgable regarding these kits....Good luck Commodore_chick!!!!! nice ride...
