New diff?
PlenumBiscuit
VY Commodore
An 3.27 LSD sedan diff from a lfx V6 will go straight into my wagon yea also with lfx V6?
What diff ratio would my 2011 Calais wagon be without looking ?
Be so worth getting one yea?
Any other alterations I'd have to do to it to suit the new diff?
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Str
Straight swap, but check what ratio is fitted at the moment, might already be a 3.27:1.
NJD-1992
VF-S2 SV6 Commodore
Physically, it's a straight swap (Just a lot has to come out to get to the diff)
Worth checking first. There will be a white sticker on the base of the diff with the ratio
Calais being a luxury model likely had a 2.92 ratio diff for fuel economy, so putting in the 3.27 will throw out the speedo/transmission, which would need a re-flash to the new ratio
I swapped out the 3.27 Open Diff on my VF2 SV6 to a super low KM LSD (3.27).
You have to remove exhaust, tail shaft, then each axle. The manual says to remove the axles from the knuckle. They are done up to over 300Nm and are a staked nut that is likely rusted, so be prepared for a **** fight.
In the end I removed the knuckle with the axles attached. Some people say to remove one side then lower the diff slightly and the other axle should come up but Im dubious if that would be worth it. Plus you run a higher risk of damaging the seals and CV boots. On your replacement Diff, id get new drive axle seals as well.
Got the job done over 3 days on axle stands. It nearly broke me but glad I done it. Bit the bullet and did the whole 9 yards, new Centre bearing, Tailshaft couplings F/R, Transmission mount and axle seals for the diff, cause I sure as hell don't want to do it again. The bolts on the tail shaft are TTY so should be replaced (Which I did cause im OCD on my car) but others probably don't. If your car is high KM, id do the above whilst you've got the drive train apart.
Im very happy with the results. I can certainly tell the car surges forward with more composure under hard acceleration. Worth it compared to the usual Exhaust/Tune
losh1971
North Tas
VE Series I SS Ute
Agree with the above, remove the knuckle and shafts as one unit. If you try to remove the hub it will probably wreck it and you will need new bearings. The shafts seize on the hub so it will take a lot of bashing to get them off. The hub nuts are like $45 ea too so if you can leave them alone it's better.
