5 volt square wave signal?^^ ever put a multimeter on the signal wire? the voltage increases with rpm. also know of a bit of a trick.. set a multimeter to 200mV or 2000mV DC (cant remember which works best) and put it on the signal wire and the numbers it reads is pretty much spot on rpm going by stock tacho.
That actually sounds pretty neat... a multi meter to tacho conversion, with blue backlights too... I've thought about this conversion way too often with other units e.g. subwoofer power drawage etc.
Are we talking about this wire from instrument connector #2 pin 3 -
"Brown/Red - Circuit 121 - Tacho signal - Voltage V6, engine running, approx 1 volt at idle, voltage increases as speed increases.V8, engine running, approx 12 volts at idle, voltage decreases as speed increases."
Hence there's no square wave signal, the whole tacho is controlled by voltage which explains Azzfox's theory on how the multimeter can show spot on revs, because if it's 12v when the car is doing 5,800 (close enough to 6,000) revs, then put through a 200mv calculation (which should half the figure) will then show the revs. If it's roughly 1volt around idle, it's most likely around 1.6v to give 800-1000 rpm.
This would be pretty cool alongside a digital Shift Light - just hook an LED up to the light and when it's bright... CHANGE GEAR!
This would only work in a V6 though. In a V8 the tacho starts at 12v and works it's way downward, which would be a pretty funny tacho and you'd have to change gear when the LED went out instead.
I think he's gotten lost looking in the wiring into the PCM / ECM as there's a 5v signal that pulses electronic ignition spark info from the ecu to and from the pcm (whatever that means!).
