@mbiondo, the indicator sound is sent to Mylink as a command via one of the data buses, then Mylink then plays the sound as directed… Same methods are used for lots of other functions that require notification…
So if Mylink isn’t working, no indicator sounds and lots of other functions it provides also wont work. But why isn’t it working?
Guess the first think to check is any Mylink dedicated fuses for the unit, as a blown fuse will mean the unit isn’t getting power and can’t talk to anything. If all fuses are ok, then you’d need to use a diagnostic tool to check whether you can communicate with the MyLink modules. If you can5 communicate with Mylink, then you’d have a bunch of U code DTC’s (one would expect) stored within the relevant modules that talk to Mylink. May be worth checking DTC’s within ynenBCm since IIRC it has/does some central hub bus translations functions…
The PDF of VF workshop manual should have the appropriate wiring diagrams for the features that Mylink is involved in. Unfortunately. the relevant diagrams are probably spread over lots of sections and it will take a while to locate then all. The PDF isn’t the easiest to navigate so best to use a PC and have the bookmark pane showing so you can click on the relevant sections as the internal (blue) links don’t work.…
Good luck with it
