DUK13Y
When in doubt, slide it out
- Nov 4, 2007
- 793
- 6
- 18
- Location
- Sydney, Australia
- Website
- www.facebook.com
- VEII SSV, VYII Berlina, '97 Lancer
Hey guys,
I have installed a 4ch amp using the high-inputs and have got really bad noise through my speakers and from my alternator itself. After trying several things like regrounding with a fatter cable in a better spot, moving wiring away from power wire, testing each channel to see if one's picking up the interference, etc, to the point where I took it to an auto-sparky. He said it's the amp causing it as once you take the power wire off the amp, the noise goes away. So he said to install some noise filters and see what happens. After doing a bit of reading and going into a store, the guy told me to use LOC's and ground loop isolators. Will this help my problem? Would I be better off buying the GLI's or noise filters? Or both?
The only noise filters I can find in stores are only 5amp too which dad thinks will be too low. On the net though I can get up to 40amp ones. I'm thinking of running a 40amp noise filter, and a 4ch ground loop isolator. Will this help or is it all just wasted money?
